I installed Ion Air on my helmet. I am wondering where and how I can install a camera on ZX14R. Chrly, please come to a white courtesy phone
Created on: 06/24/16 09:42 PM
OldMan
Camera mounting place
06/24/16 9:42 PM
chrly
RE: Camera mounting place
06/25/16 5:34 AM
Took me a while to find the phone but here is the pic.
I am amazed that these mounts hold..They are just glued on..
I have had about four Contours over the past few years and for me, they seem to do the best job if you consider all options. With that said, I have not played with any Hero except the very first one years ago and once I found the easy on/off of the Contour, I stuck with it.
* Last updated by: chrly on 6/25/2016 @ 5:35 AM *
06/25/16 9:16 AM
I also have a contour mount on my swingarm. The back corner never quite stuck to the sharp rounded edge but all the rest is still totally reliable after 3 years. There is a lanyard on the Contour to so if it ever did come unglued, you would not loose it if tied up.
* Last updated by: Rook on 6/25/2016 @ 9:18 AM *
chrly
chrly
OldMan
06/25/16 1:02 PM
Chrly, thanks for the pic.
Rook, a good idea but does it take images other than back of your foot?
06/25/16 1:57 PM
Rook.. Is that the Contour GPS ?
chrly
ZXKawi
rod442
ZXKawi
darkarcher
09/14/16 5:01 PM
* Last updated by: darkarcher on 9/14/2016 @ 5:03 PM *
Nightmare
09/15/16 6:50 AM
I've been contemplating permanently installing a camera that records whenever the bike is on (like a dashboard camera) in case someone does something stupid like pull out in front of me (like last night). So I was wondering if anyone has tried hiding a camera somewhere on the bike where it would be more likely to survive a crash, isn't obvious so it wouldn't be easy to steal or the police wouldn't be able to use it against me if I got pulled over. :)
I was wondering if anyone has tried mounting the camera under the windscreen behind the instrument cluster or if there are other suggestions.
09/15/16 9:29 PM
otherwise, inside ram air scoop. cover with mesh to conceal it. black tape the ON light.
a helmet cam would do the trick---maybe hidden inside a mohawk.
Nightmare
09/16/16 10:40 AM
The features of the camera I had in mind would be weather proof, powered by the vehicle and would record in a loop (records over the oldest file when the memory is full) every time it powers on, so the only time I would need access to the camera is if there was an issue.
My 2 major concerns about behind the cluster under the windscreen is whether or not the camera could actually see well (its a tinted windscreen, but that could be swapped, etc) and space, its pretty tight behind there. I was thinking about possible cutting a small hole but didn't want water getting in to that area.
I was also thinking of the air intake, but not sure if that would have a significant impact on air flow. Guess all of this really depends on the overall size of the camera. The Contour camera that you have there Rook looks pretty small, but doesn't look like it can be powered by the vehicle and remain weather proof at the same time, nor does it seem to have a recording loop feature.
Nightmare
09/18/16 7:44 AM
Hey, if you use a steering stem mount, take it out after every ride. My techmount has o be removed by taking off the fender and inserting a dowel below the steering stem and tapping with a hammer. I think the orings swelled. Seems to keep getting tighter as the years pass. PITA
